I'll publish the results and some comments during or after this weekend.
20 people have voted so far.
Which price would you pay for such a device?
We can clearly see a tendency to a more costly device with more features.
Do you need a display?
Most don't need a display.
Some want to have an expensive graphic LCD.
So I think we should not include a display by default. With display it would just get too expensive.
Do you prefer the old style DIN connectors instead of the modern RJ45 ones?
Only very few like to have to old DIN connectors.
RJ45 is my favorite, too. They are much less expensive and are available as surface mount which makes manufacturing easier.
One PL connector carries left and right channel. One is enough but two are more convenient. How many?
It's 50/50. No problem here when using RJ45. So just let's include a second one.
Do you like to have a standard 38 kHz IR receiver for non-Beo remotes?
The majority don't want to have "normal" IR support. Let's leave that out. Of course it can be added very easily by soldering a wire to any GPIO.
Do you prefer having a 455 kHz IR receiver and a few buttons directly on the board instead of using the silver IR eye?
Again 50/50. Let's leave that out for the moment. If that device will come reality I'll order a batch of some old TSOP7000 from china. Some sellers still seem to have them in stock there. Feel free to just connect that to the IR eye screw terminal we'll add anyway. It's compatible.
Is wired ethernet important for you?
Exactly the half want to have a native ethernet port. I can understand your concerns. Although I think most people will use WiFi anyway, let's integrate it.
The device features analog and digital inputs. What would you like to connect there?
Most want to connect their BS or BV to the analog input. I didn't expect this but it's totally fine. One more reason to have a PL input and not just a regular RCA one. Nevertheless the ADC I had in mind offers multiple inputs and we can also include a "normal" LINE-IN if there is enough space on the board in the end.
What about the case?
Hm, there is a slight tendency to just the plain PCB. Nevertheless shipping with a simple case is never a problem.
Which BL speaker you want to connect?
Just what I expected here. BL6000 and BL8000 are the clear winners! No reason for even thinking about the WISA generation.
Which streaming technologies are you using most?
Airplay and DLNA followed by Bluetooth and finally by Spotify Connect.
Are you interested in controlling old ML devices with open source hard+software?
Are you owning a BL5000 or 7000 remote?
Some people seem to be interested in this. Let's keep it for a future project.
Make a wish!
One request was IR translation support. Not sure whether this makes much sense for standard integration. Which direction do you want to translate?
Another one requested digital out support. Okay, the processor we are using offers S/PDIF out. We can bring that to a connector. Might also make some BL5 owners happy.
I'll keep the results in mind for creating a first sketch if I'll find some time over the next days.
Will keep you posted here.
