Thanks - that is acutally done in the BeoLink Gateway - but it was triggered by the My Buttons on the BeoSound Level
Brilliant! Are you running the forthcoming NL software update on the level for the BLGW to see it?
I love the essence remote on the wall.. Are you using it as a music controller or as a macro trigger on the gateway? I have a table top version connected on BT to my essence mk2 (for music control) but appears to go to sleep ignoring the first press if not used for a while. New batteries makes no difference. I'd love to have more through the house working as light switches to my BLGW, but having to wake it first makes it a no-go. Perhaps IR mode is more reliable? Cheers, Rob.
Hi EBNROB
No the new software for the BeoSound Level isnt out yet, so it is not integrated with my BeoLink Gateway - The my buttons on the BS Level is stored as GVA commands as is "Turn on light in livingroom" and then it sends the command to the Philips Hue Gateway -> then the BLGW picks up that the light over the diningroom is on and triggers a command in the back to light up the cabinets. (makes sense?)
