Thanks to Dillen
General shout out to Dillen for supplying belts for my Beogram 5005 and Beocord 5500 - both fixed up a treat in about an hour. Full instructions provided (a double-up of instructions for Beocenter 9500 and Beocord 6500 but in the end it worked out sweet!).
The Beocord 5500 is such an easy deck to work on compared to the 3500 which I've fixed up before. Sooooo much more simple.
During the repair I noticed the disc clamp for the slider belt was loose - the nut which holds it in place had unscrewed a bit. This was causing a 'scraping' sound each time I used the deck drawer. Tightened that up and the drawer's nice and smooth again.
Tapes play properly now and wind speeds have improved by several seconds.
The Beogram sounds 'lighter' and some classical pieces with sustained notes really do shine now.
Very happy so a big thanks to Dillen!
Beofan for many years with a penchant for 1990s audio systems.
It has to be said that Beoworld would be a much poorer place without Martin. He has so much knowledge and is always happy to help. He is also a really great guy and I am proud to call him a friend.
Agreed !
Dillen helped me rescue a Beocord 5000 many years ago
I'm new here, although I don't know Dillen, I agree with all of you.
Thanks guys.
B&O, collecting, restoring and repairing has been a hobby for me for more than 35 years.
Having such a lovely bunch of Beoworlders to share it with, is just wonderful ! 😕
Hi Martin,
While we're on the subject of Beocord 5500's, I have a question: Mine plays back fine, when hooked to a conventional amp.  You see the previous owner cut the DIN plug off and wired 2 RCA's to the green and blue leads.  I would like to re-install a 7 pin DIN, of which I have one, a solder on type.  The pins are numbered (and I can't read them very well) in an odd fashion.  I could probably solder them on, carefully, if I had a diagram of some sort.  I'm assuming the woven copper surrounding the wire is a ground.
Thanks in advance for your help,
GJS
http://beotech.beoworld.org/mclconn3.htm
I've to say that Martin was the second person on BW I've got the pleasure to deal with you, I'm very thankful for our you help since and to come 😕
You're real gentleman and tru gem of this forum
bob
Dillen wrote:
Thanks guys.
Thanks for that, Beobuddy, now I just need a schematic to tell which wires are what color...
3 Left, 5 right, 2 shield inner wire, 6,7 data, shield outer cable ground on shell, but B&O changed the colors a couple of times, check your schematic for data wires, normally  shorted in the jack and use the pin 2 as ground, left and right you can check connected
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
