Testing and comparing BL2
Eventually I am going to have a listening test of BL2 (and compare with B&W PV1) and I would like to be as critical as possible.
As many Beoworlders claim BL2 is not that good a subwoofer when it comes to music (I am not speaking about movies here), I would like to know in your experience which specific music types make BL2 sound the slowest and the most boomy, in order to test with this kind of music as well.
Thank you all for your valuable input.
Jean-Sebastien
I turn mine OFF when listening to music. (Bl8000's & BS4). Its too OTT
Indie (Alternative), Rock, Pop, Classical. In that order.
It generally struggles with any music with a fast/detailed bassline - I'd recommend some electronic music to particularly show up any limitations in loudspeakers...
Actually having compared Pentas and a BL2 against M100s, which have 12" woofers, the BL2 sounded quite overblown with all music. Before doing this, I had not really noticed as I think one gets used to different sound types, but in direct comparison, the bass of the M100s was far more detailed and taut. I therefore think that the performance of the BL2 can be improved. BL5s clearly also are markedly better - when you listen to them you are not overwhelmed by bass but notice the detail. Your neighbours might dispute this !
I'd actually go as far as saying the BeoLab 5s provide the most controlled, smooth and dynamic bass I've heard coming from a pair of speakers...
I've personally only found the BeoLab 2 sounded slow
when it was placed in a corner. Moving it away from that
corner and a foot away from a wall solved the problem.
In terms of detail it sounds like there are subs out there producing
more nuanced low ends but I definitely like the warm, full results I get from
my BeoLab 2 with all genres of music including very bass heavy genres
like drum and bass and house music. I don't really play music much
above a moderate 40-46 volume level. Perhaps at higher volumes is
where these issues become most apparent.
I've always enjoyed my BL2, and have been somewhat mystified by the "slowness" comments from critics.  I haven't heard it.  I always figured it was the music I listen to, my hearing (although it would seem like even bad ears - and I think my ears are ok - would hear "slowness") or perhaps the critics' system (BL2 in corner or not optimally placed.. or perhaps just a difference of opinion, but so many with this different opinion... 👍 ).  I was hoping somebody would post some specific non-obscure tracks so I could hear, definitively, this slowness.
Come on people...  post some tracks... it shouldn't be hard... everybody knows the BL2 is slow and not at all suitable for music 😕
Stan
I'd recommend 'Karmacoma' by Massive Attack...
