Login to view imageYes, this where I toggled one of the fields off and then back on. The favourites then appeared.Not sure where you do that… There is a setting where you can toggle eg favourites on / off but It did not help.
Test Flight App --- TUNEIN
Yep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&OYes, this where I toggled one of the fields off and then back on. The favourites then appeared.
No luck… Login to view image Login to view imageYep, to see the favorite you must turn all the other options ON …. Another issue to be fixed by B&O BS Moment, BS Core, BG 4002, BC 4500, BS1, BL18, BL19, BL8000 + RCV1, A6, M5, M3, A1, P6 (tks Botty), H5, TR1
You must close the app (swipe up in IOS) for the change to be effective (another bug)No luck
The only thing that helped me, was to toggle on ALL 4 categories.
Usually I only have the first = Favourites set to on (that is what I need).
Afterwards you can toggle off those that you don’t need….and the Favourites appear 🤩
Not very intuitive, but it worked.
Up to the point you close/start the app. The choice is not persistent unfortunatelyAfterwards you can toggle off those that you don’t need….and the Favourites appear
What do you mean by ‘close/start the app’?
Close = swipe up the app in IOSWhat do you mean by ‘close/start the app’?
