Test Flight App --- TUNEIN
Hiort wrote:
Still no update to fix the Radio mess up…. 🙁
This issue is as far as I know limited to the beta app. It is really expected that there are issues with the beta app, that's exactly why there is a beta version.
Absolutely,
It’s just that MrAndersson said that they would look into this the first thing this Monday. It’s quite a big error even in a beta release.
Hi guys
Sorry for the delay, it turned out to be bigger than expected. We're on it and I expect a fix today or start next week.
While under construction,
It would be nice to display the radio page according to what is supported by the product itself instead of defaulting to B&O radio, should be as easy to code than selecting the appropriate product image.
@ Mr Andersen- also I cannot start tunein stations from BO app on Essence MK1….only way to listen is to start tunein on iphone and stream to Essence 😔
Any way to fix this?
I do not heave a Mozart product yet to test B&O Radio but from the interface I see in the app it seems that a few additional functionalities would be required to get on par with TuneIn:
  • It seems you can only have 4 favourites mapped to the MyButtons. It would be nice to be able to manage favourites like in TuneIn where you can edit the order and map them to the number keys on the BeoRemote One.
  • In TuneIn you can manually add custom URLs for streaming of stations that are not directly available on TuneIn. I don't think B&O Radio provides this function?
  • In TuneIn you can check the bitrate of the stream, which can be useful from time to time.
If these functionalities can be supported the only remaining plus of TuneIn would be integration with other products. In general, I think it would be nice to have TuneIn on Mozart and B&O Radio on the other products. Not sure how feasible that is however.
New release tonight.
Same problems for me unfortunately…
Didn’t work for me either until I “personalised” the Radio menu. Then the favourites reappeared.
Tim
Tim
Not sure where you do that…
There is a setting where you can toggle eg favourites on / off but It did not help.
Same here, I don’t see TuneIn favorite fixed
