I have a BV8-32 and added the Systemmodule with DVB-T just yesterday. At the time of installation the module was not available.
Connected to the BV8 is a Technisat DVB-S2 Receiver via Scart and HDMI on AV1. This was controlled via PUC and as DTV. Now with the new module the DTV is used by the DVB-T module that I do not need. The Receiver can just be controlled as V.AUX - very inconvenient!!
Is there a way to switch off the DVB-T Module? Can this perhaps be done in Service menue? How to enter service menue??
Thanks, Heribert
in a short answer, no you cannot switch it off.
The only way you can get the DTV button usuable again is to remove the module.
Any other ideas? Can I connect it as V.MEM? I tried but could not add a STB Control...
Is the BV8-32 so different from my main room BV8-40?
i think but dont quote me on this. if u update the tv sw it might let u use v.mem for control..
Heribert wrote:
Any other ideas?
Yes, if you don't need DVB-T, just ML and SCART:
Use system module Type 4375 (without DVB-T - PartNr 1437500) instead of your current Type 4470 module.
Both types have the same price.
Sometimes less is more ...
The solution was quite simple.
1) It is not possible to switch it off on BV8-32
2) My dealer exchanged the BEO4 to a version with V.Aux as hard key. Instead of TV + DTV it has DTV + V.Aux...
Thanks,
Heribert
