swapping stands on MX4000
i have another question about my MX4000 😳
the tv came fitted with the standard bar type stand but also a seperate motorised which i naturally want to fit but have a few q's before i start
1. the screws holding the bar stand look special, do i need a special too to remove theml?
2. how do i handle the tv when swapping stands? Is there a special technique? its a heavy unit and i don't want to break anything
thanks once again
pb
The trick when changing the stand is to turn the TV on it's side.
You will have to give a better description of the screws. Could be Allen, Torx or Posi. What do they look like?
