Sw 4.24 has now arrived for BV7-40/BS3/BV9
Hei,
Can BV 7 with the new update read the audioformats on Blue Ray: Dolby digital plus, True HD, DTS-master and PCM.
Trucker
High definition and BluRay look stunning on the BV-7. I am sure the TV is not Gray. B and O installers both said it was not gray, but silver. The color on the TV is identical to an old BS1 cabinet we have next to it and very close, almost exactly the color of the ALT. The serial number does come back as being Gray according to B and O.
I will try to post some pictures, if everyone will excuse the mess of wires behind it. Will sort that out after the new BV7 is installed.
The dealer took the box with. They checked serial numbers howver and box said gray, serial number is listed with B and O as gray. I do not know if they compared serial number on TV to that on the Box.
How do I post pictures here?
I just noticed that when turning a CD off in a Beosound 3000 connected to the BV-7 that instead of instantly turning it off, the volume slowly fades away and then turns off.
