having dreamed of owning a pair of beolab 8000's for a very very long time i managed to persuade the wife to treat me at my expense lol
unfortunately in the quest to buy I came across a pair of Beolab 1s which changed my outlook and they are now taking up prime position in the room.
sadly these are curently my only b&o product and they are connected to a panasonic surround sound system using a convertor from SoundsHeavenly which does the job of dropping the amplified signal down to line level.
the sound from the 1s is amazing, but this has now prompted me to start looking for somethng from B&O to use as the rear surround speakers.
Based on looks id like Beovox 3000s and these could be run from the existing panasonic without having to worry about mains power, alternatively I could potentially fit either 4s, 6000s or 8000s with a bit of messing around.
The room isnt very big and I think 6000s or 8000s would be overkill, and ultimately what ever speaker is chosen will only be providing rear fill and there is currently no plans to change the panosonic unit until it fails.
what would others recommend and why?
