Surround Sound : BL3 Front, what in Back ?
I currently have a pair of BL3 and a BL7 center speaker on my BV7. I am looking to complete the surround sound set-up with a BL11, but what to put in back.
I have read on other posts about BL4, BL4000, and BL3 as Back speakers. I wonder if BL3 would be too much. And BL4 not enough. And I don't have the space tp put anything bigger in Front ...
I would love some feedback and advice. Thanks !
- Scott
I used to have a 7 with 8000's at the front and 6000's at the back. As they weren't that used by Beosystem 3 for the price, footprint and cosmetics they were perfect.
They are currently a bargain at the moment too, so you might have enough spare cash for a Beolab 2. Much recommended :-)
The Beolab 4 sound good for the size but The Lab 4000's are a much better speaker in every way,there again Beolab 3 would be anther jump up in sound and also the ALT on them,which you have at the mo!  Having a set of Beolab 3's all round would be the same in the set up!
Try and borrow a set of Beolab 4's...4000's and of course a set of 3's as well.
I use a Beolab 4000 for my center on the Bv7-32 in the bedroom with 6000's and the 4000 is really great as a single center! There great as surrounds too.
A member called Elephant on this forum has a set of Beolab 4's maybe he will post if he reads this, about his set?
Good Luck on what you decide!
Hi
The back speakers are not so important. I have the choice between 4 bl3 and bl3 in front with bl8000 in back. FInally I choose the second solution just because I love the look of the 8000 and the bl3 desserves more than the back position.
I would suggest BL3
- balanced power if you select speaker4
- continued ALT and ice power technology
- last, esthetically balanced as well
I probably like Lab 4 more than most, especially as rear speakers.  I just don't care for the floor stands because of cable management. Plus you could run them through a BL11 for much less than the price of one BL3.  Another alternative is the BL12-1.  Very nice, but you have to convert the cables to RJ45.
Hi Scott,
I have a BeoVision 8-40 with BL3's as front, BL4's as back and a BL11 - AND I LOVE THEM!!!
I bought a pair of used BL4's a few years ago, because I couldn't afford anything else at the time, and they are actually okay. At some point I want to exchange them for something else, but I don't know to what. Have thought about both BL4000's or another pair of BL3's, but don't want to spend that much money on rearspeakers. Then I would rather buy a pair of BL9's as front, and move the BL3's to the back?! In my opinion the BL4 work great as rear speakers in a surround set with the BL3's and BL11 - alone as stereospeakers, I don't like them at all!!!
If you can borrow a set of BL4's and a BL11, then try them together with your BL3's. 😁
Kind regards
Claus
Yes !
I have experimented with BL4s as rears - and even 4 x BL4s (front & rears) to see (sorry hear) the effect of having the same speakers (my fronts are normally BL3s).
Unlike Claus and Symmes I was disappointed.
Maybe it was my choice of test movies.
Maybe I should have left it all running for a month.
So for me there was not enough oomphf !
But for my wife they were too much.
She really hates surround sound - she keeps look behind her to see what's going on 🙂
And as mentioned having the right stands and cable management was a problem during my tests.
Another "no no" from the wife.
So I suspect that the BL4s would prove to be adequate - depending on the source movie.
Certainly I am happy with them playing music in small link rooms.
