Mace wrote:
Thanks for all the feedback.
I can see, that i should have specified my setup. I use a Denon X3000 surround-receiver as a pre-amp. As far as i have understood, with odyssey on and rear speakers set to 'small', and 'no subwoofer', it will send the bass to the front speakers (the LFE + other speakers at their given cross-over).
I have listened to the beolab 9 (and they sounds great), but as i am buying 2nd hand, i can't try it in my home. That's why i wanted your opinions, from real life situations..
I would agree with Geoffs assessment, especially as he is a trained expert, and I am not...lol
But, an Beolab 9 is a better loudspeaker than a Beolab 3, apart perhaps from size and discreetness.
I use a pair of Beolab 9's, along with a V1-40 which I bought new, and do not feel any need for a separate sub to handle LFE.
In fact, when I first got the Beolab 9's, the bass was so good, on both music and movie LFE, I couldn't believe it for the size of the speaker, and was initially terrified that something would break - i.e. a bass driver voice coil slamming into the magnet end plate and destroying the voice coil, or some other electro mechanical disaster. But after Geoff so kindly wrote in and explained how B&O's ABL (adaptive bass linearity) circuit works to both extend the bass and protect the speaker from overload, I felt considerably more at ease with my new purchase.
Eighteen months later they still surprise and delight me with their bass capabilities on movie LFE.
My room is solid concrete floor and ceiling, with double brick plastered and painted walls (being an apartment) with carpeted floor and around 5 x 4 metres in size, with 2/3rds of the end wall being ceiling to floor glass overlooking a balcony.
I usually listen on movies (Bluray) at around 55 - 60 on the volume, and at that, LFE is enough to rattle doors and windows on some movies, and makes the couch go all wobbly as well!
As far as low bass/LFE is concerned, I've accordingly never experienced a desire for more bass volume via adding a separate sub.
Something like a Beolab 5 or it's successor might tempt me though, but mainly only for my favourite pipe organ music where I really want to feel those 32' stops doing their thing at 16hz, but for movie LFE, I'm very well satisfied indeed.
Accordingly, I'd recommend the Lab 9 solution, with 3's at the rear, given the options you've stated.
Hope this helps
Kind regards
John.. 😐
