Subwoofers with Beolab3
Jaffrey2230 wrote:
I have both BL 11 and BL 2 in my set up and there is just no comparison. I have also owned a variety of other subs. The BL 2 is totally in another category when it comes to performance compared to the BL 11. The BL 2 is one of my favorite subs out there from any brand - I even prefer it to the BL 19.
I know some mentioned the Cambridge Audio Minx X201. Interestingly, I have post here somewhere where I replaced my BL 11 at one point with a single Minx 201 and once I had adjusted the settings the tiny Minx X201 outperformed the BL 11. If you get two Minx X201s, remove the grills and connect them together (the Minx has an audio out connection to link multiple subs) you end up with an aesthetic that would work well with your BL 3 and you'd get performance that would blow away the BL 11 - by a long shot. Yes, I have the BL 11 in my set up only because of how great it looks, if I wanted better sound, I'd get any other sub in a heartbeat.
My 2 cents worth. FWIW, I find the combo of BL 2 with either BL 8000/8002 or BL 3 to be a perfect match. They sound amazing to me. BL 2s are quite cheap right now, I have no idea why, but in the US they are 50% cheaper than a BL 11 (I guess form over function has a lot of value)
I completely agree. I thought the BL3s sounded great for their size. When I added a BL2 to them, I was amazed at how the BL2 elevated them to an all new level. The improvement that a BL11 adds is very subtle.
I have the BL3 and BL2 combo and I really enjoy listening to music from the speakers.
I am using the recommended placement setting for it and the BL2 is adding the needed lows. Especially since our room is fairly large.
I like my BL3 and BL2 combo a lot.  However, I have them run from a Beosystem3 so the extra sound control could be a factor vs just running them through the crossover in the BL2 or a system with less control.
OldJack wrote:
Did you try to make some bass adjustments on Bsys3 with your Beolab2 ? I am using it for music and movies,sounds excellent to my ears...
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
I’m using it with a Beovision 10 at the moment, so I’ve no idea how to adjust it.
Maybe one interestng combo...BL8000 and LINN SIZMIK 10.25.
It takes some time to adjust..but end resolt is wauuu.
