Hi Steve. Witch version off the B&O app you have? Because we have Get information that this update should come 31/5 but have Been postponed because off some issue.
so Wonder witch version you have Get off the app to Get this work.
available in version 3.13.5 (latest in the App store)Hi Steve. Witch version off the B&O app you have? Because we have Get information that this update should come 31/5 but have Been postponed because off some issue.
Strange.. her its only 3.14.0.37144 and that is test software.
do you have a test software? Or is this release in UK?
I read the sw wrong. Seems i have a newer version.
then i will test stereo pair tomorrow :)
Great news Steve and thanks for posting.
What happens if you try to un-pair (separate) them?
I tried this feature (not through the app) but the hard press of buttons on the A1 to pair them. And when i tried to use them independently, it would always look for the second one and it would get confused.
Even factory resetting them hasn't made them the same ever again.
It might be diff technology but the principle is the same.
this version as well. The picture was actually made in this version (because of language).Strange.. her its only 3.14.0.37144 and that is test software. do you have a test software? Or is this release in UK?
Edited.this version as well. The picture was actually made in this version (because of language).Strange.. her its only 3.14.0.37144 and that is test software.do you have a test software? Or is this release in UK?
actually the latest build beta version doesn't show this feature! roll back to the previous build and it will show.
Is this the long awaited new mozart feature?
Its a feature that is only implemented on the products using the Mozart platform as I understand it.
Any hope to see this on non-mozart speakers like the BS1 or is this a hardware limitation?
For this feature Mozart platform is required. So I guess the answer is no.
Just stereo pairing or also surround pairing?
As of now only stereo, since its only involve stereosource. I heard rumors that Eclipse and Harmony will get possibility to use devices on the Mozart platform as regular speaker. In a surround setup I assume.
Is the only way to play to the group through the b&o app (which makes sources very limited) or also via AP / CC?
Not sure. Lets see when Steve have tested 🙂
IPossible to join the pair via “touch to join”? Or via an essence remote?
Touch to join is not present on the Mozart platform.
ICan the stage be paired as center for a 3.0, 3.1 or 5.1 setup?
No
Hi everyone,
Just to clarify that I updated my iOS devices to the latest app version in the Apple store and my Emerge is running software 1.6.24053
This may not be on general release yet, as further updates are still being rolled out. It will go live across the "Mozart" speakers (Emerge, Level and Balance) in the coming weeks for stereo pairing within the B&O app.
Further details to follow once I can test two speakers in stereo...
Kind regards, Steve.
