STB upgrade, how?
I am trying to find how to upgrade the chip in a beosystem-1. I have the new chip but where is the current chip placed?
I hav tried to remove the small plate arount the scart connectors but it wont come of even when I have remover all screws.
I have tried to remove the big cover after removing all screws, it wont come of. There is some other black dots that looks like screws but there is only a round hole in the center so no screwdriver will fit there...
Any clues?
I have found the stb fitting guide on beoworld section with guides but it is only for avant´s
Maybe download the service manual for you Beovision/Center 1
Yes I did, just that I had the beosystem with the back / connections facing me so I went the easy way and thought I could remove the back plate without unplugging the screws on the other ends (top and side) of the chassi ;)
Anyway. I replaced the chip, I now see a new list. I accidently ordered the wrong chip. I got the motorola vip-1910 and the chip has the codes for motorola 1920. I got the 8344784 chip.
I have attached the ir remote on the front of the digital-tv-box exactly where the ir-reciever is, I have put a scart at the av connection and named it stb(dtv) in the menu. Still cant control anything. I can see the box´s picture when pressing dtv but nothing changes when I press control buttons lik up/donw or numbers or anything...
What am I doing wrong?
I must be the most unlucky person on earth if the 1920 code cant do anything on the 1910 box. The remote controls are almost identical...
Start checking your ir-lead by using a camera from your cellphone.
You should see the ir-led flashing.
Good point there.
I cant see anything flashing at the end of the ir-out-lead on the black attachment "thing" when pressing anyhing on the beo4.
Guess the lead is broken then..
When I look at the original remote for the stb I get at bright light in the camera.
You're sure that you haven't disconnect a cable inside?
As you have to slide the internal chassis outwards, maybe something went wrong?
Verified with a new cable. The first one was not working :)
Thanks for the suggestion about the camera check.
Now I can control the box even though it is not exactly the same model in the list.
