STB Sagem DTR94000 TA HD
Hello out there,
I have a BV 8-32  connected with a STB Sagem DTR94000 TA HD. It works fine together with the Beo4, but the sound in the BV is very  low. Of course I can turn the sound higher on BV8, but with a lot of noice. Does anybody know if it is possible to adjust the sounds level in STB?
Edde
Should be possible. You have to use the Sagem remote and set the output level of the stb to maximum. Now you can control the stb level with Beo4 via your Beovision. Hope this helps.
Stefan
Thank you
It works
/E
