Hi all
I've got a static charge going through my Beo Sound 9000 stand when the sytems is turned on....any idea if you can earth the stand at all?
Thanks in advance
Ian
Hi all
Thanks in advance
Ian
Actually, this is quite a common issue particularly on very dry days, not a lot of those lately in the UK.
The Beosound 9000 along with most other modern B&O equipment does not have a mains earth connection because the chassis and signal grounds are isolated. You can earth the stand without problems. If it is near a metal radiator pipe, that would be OK for a static discharge path.
Thanks Keith. How do I go about earthing the stand like this?
