Starting over with Beomedia.
Assuming your computer is on the same network as the beomedia (and you are using a windows pc) in windows explorer / my computer you should see a network drive for the beomedia1 with 4 folders, favorites, music, photos and system. You can drag and drop files or remove what you dont want directly from there.
Regards
Peter
Yes it will update automatically. In fact I find it easier to put media onto beomedia 1 by drag and drop. Then on my PC i use windows media player 9 (not 10 as it dosnt work properly with bm1) and set my library to the bm1 file share. By the way you can store lossless files on the bm1 by using windows media player as beoplayer will not rip to lossless.
Cheers
Peter
Thanks Peter, this makes life a lot easier. Why would any one use the beomedia software? It's much more cumbersome.
Best regards,
Peter
