Hello,
Puzzled by the various rules and restrictions on what can pair/connect with what I started a what I call compatibility matrix. The FAQ on this topic is a very good start but still leaves a few holes.
I have not taken into account the compatibility between the different country versions, that might well be the next step.
I would like to invite all who have some information, comments, suggestions and corrections to help to make this information as accurate as possible.
Here is the first draft: I am looking in ways to add the part numbers of each item to avoid any confusion and make it easier to identify the type of handset/base station you have.
| Handset model | Beocom 6000 base Pyramid | Beoline I | Beocom 2 base/charger | Beoline EU Mk II |
| Beocom 6000 MK I | yes | no | ||
| Beocom 6000 MK II | Yes, base FW level 2.5 min | yes | yes | |
| Beocom 2 pre 2002 | Only with fw upgrade on handset | Only with fw upgrade on handset | yes | no |
| Beocom 2 post 2002 | yes | no | no | |
| Beocom 2 MK II | ? | yes | no | yes |
| Beocom 1 (US only) | ? | ? | ? | ? |
| Max 6 handsets | Max 6 handsets | Max 1 beocom 2 | Max 8 handsets | |
