Reference here is to Audio System Only.
I have a Beocentre 9000 in the central room. This ML equipment has its AV output connected to an ML/MCL converter. The converter feeds an MCL network to several link rooms. Each of these rooms has either X-Tra Speakers or X –Tra Active Speakers kits installed.
I currently have a problem. Whenever the remote (any B&O type) stand-by (red button) is pressed in any link room, it also shuts down all the link rooms being used. This switches off the ML/MCL converter in the central room causing this situation. The Beocentre 9000 in the central room is not affected if that is being used at the same time.
I have tried putting all the various options into the eyes associated with the each speaker kit in the link room but cannot overcome this problem. I would appreciate if someone could offer some advice?
