Ive got a CX in Australia - and the LG has all the Apps that I’d used the Apple TV Box for..... that said if there was another app I’d needed that wasn’t on LG I’d plug an Apple TV back in.
Stage / LG / Stand user experience
I'm interesting in this setup (Stage/LG 65'') especially the control with BR1.
I have now a Panasonic with connection hub, TR1, Beolab 18/19 and Beosound Moment.
Is there an option to connect the Beolab 18/19 and Beosound Moment to the Stage/LG combi???
I know the LG has WISA, works it fine with Stage as a center speaker and Beolab 18/19 together?
Don’t think it will work to have 18’s wisa connected to the LG and use the stage same time. There is no sound processing in the LG.
The stage and moment with BL18/19 can be connected though multiroom
I was afraid for that.
Is it possible to control the LG directly with the BR1 without the Stage?
LG has a WISA module I've seen, with equalizer etc... Maybe a Almando Surround box is the better solution
Are you looking for a surround sound system? The LG/Stage will act as an very good 2.0 TV setup, For true surround you need both front and back speakers and sub. For music the stage and Moment+BL18 can act together and provide a good sound stage! I don’t think the LG/Stage can act as an surround system with a Almando surround box. Maybe someone else can comment on thisI was afraid for that. Is it possible to control the LG directly with the BR1 without the Stage? LG has a WISA module I've seen, with equalizer etc... Maybe a Almando Surround box is the better solution
I have the 18/19 combo connect to the TV and BS Moment, Stage is not necessary when I can control a LG with BR1 without stage.
I would expand in future with back surrounds.
So at the moment I have an 2.1 setup and want to upgrade the tv and later to 5.1 all control by BR1. I think it's impossible.....
I think it's LG/Stage with BR1 or LG/Almando without BR1.
Stage and 18/19 both connect to tv seems a problem
