Special Invitation
@mjmedio - I guess your dealer (like all others) won't tell anything. They are stricktly forbitten to say anything!
I am very curious of the new remote.
Will it be a remote especially for the 'new Avant'? I hope not - we have seen such things before.
If it will be a successor for the Beo4, it might be very important. The remote is what we use for interacting with our B&O-gear (and the 3.party gear as well). Will it be a remote for a new way of interacting or just a re-designed 'old' remote?
Look for a beolink 7000 throw back
It will be cool I believe
The avant I'm hearing is very cool with a moving speaker that expands from the center.
I think there will be some magic again!
Chris Townsend wrote:
Any ideas if
2: Will it be lit so I can see it in the dark?
I was told yes.
Also, dealers will get the TV a couple of days before.... :)
How do you manage to upload pictures??? I wanted to show the invitation received.
You must use the 'Reply' button and then choose 'Options' and 'Add/Update' (File attachment) to find the picture you want to insert in your post.
Note - You can not do this from an iDevice!
I have been told also that the new TV will have moving speaker and a new remote. Price for the 55 inch model will be €6995,-
I'd guess that will come it at £6000. If so, that's extremely cheap for a 55" B&O. Cheaper than my BV11-46! Which means my BV11-46 will be worth a lot less after the release of this new TV!
55", 4K, reasonable price, new remote. Interesting times.
Thanks, hope you could see the picture attached.
