Speakers for Beovision 11-46
I have a Beovision 11-46 which I've owned for 4 years and am happy with the tv picture but would now like to improve the sound.
Can anyone suggest speakers.
Thanks, Alan
We had BL8000 as front and BL6000 as rears, worked well.
Both MK2 versions
If you only have room for one....get a BL11, a BL19 or a BL2.
Beolab 9 or 20 as fronts.
No subwoofer needed with these.
Excellent stereo speakers.
If you want surround sound, rear speakers can be just anything, they are just for sound fx.
We put our older Beolab 8000 in the back when we bought the Beolab 9.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thank you for your suggestions.
Our room is about 20m2 so not very big and I think something like the BL20 would be too much for the room.
I see that there is the BL3 which is a smaller than the BL9 and might be ok.    Also considering BL6000.
Or, could splash out on a new Contour!!
Thank you again for advice.
I can advise BL17’s, they will give you such a good sound with the BV11!
