If I'm not mistaken, I will need to deal with (at least) two problems:
1: Due to the size of the room, I will need a lot of speaker movement; therefore, speakers with many watts (or several speakers with lesser power that might become a problem dependent on their placement and combined projection).
2: One of the more difficult challenges I'm facing is the large areas of glass in the room, which will likely cause significant sound reflection issues. The room's floor will be hardwood with carpets, and there will be no curtains. I'm open to any ceiling material that can help mitigate these issues, as long as it's visually not too bad.
I wouldn't say I like B & O's floor-standing speakers much, such as the BL90s, 50s, or 20s. On the other hand, I'm quite fond of their wall-mounted options, such as the 18s, 17s, 12s, 8000s, and 3s, when wall-mounted.
I'm sure neither of the speakers I like can provide enough speaker movement independently. Even if I use a par of BL50s, I will lose around six DBL every few meters, so investing in those might not solve the problem, and they will make a significant hole in my budget.
On the other hand, If I use several pairs of smaller speakers, BL17s, BL3s, or BL18s strategically distributed across the room, combined with one or two BL19s, I might get enough sound volume. Still, I will likely need to solve the problem with sound reflections.
I understand that what I like and don't like makes a tall order and is challenging to meet, but as this is a forum, I thought that maybe some of you have thought across the same line of thought, and I would love to hear what you think. Have you, for example, managed to solve similar problems, or do you have suggestions that might help me, especially regarding sound reflections? I would also be grateful for suggestions on ceiling material that could help minimise the reflection issue. If I find a solution or an acceptable compromise, I can leave enough space between the glass walls to mount the speakers before constructing the room, while I need to decide which speakers would be best for this room. Also, I'm sure I've forgotten additional factors and would be grateful for any hints you could provide.
