Hello there, what would you prefer if you needed speakers for your Beocentre 2200? I have the choice of both and need smaller speakers. Should I go for the older S45's or the CX's, which of course are newer. Dont think there would be much in the reproduction, or would there. Any advice would be great. Cheers.
Speakers-- CX50 v S45
The big advantage of the CX50 is the small size. If you have the room, go for the S45. Do note that there are three versions of the S45: The original and the -2 are both three way speakers, whereas the newest version is two way. The three way versions are supposed to sound better.
Which version of the S45's? There were two, plus the 45.2.
I've just refoamed one of a pair of the later S45's and been playing it through a BC3300 and was quite pleased with it. It may depend on what you intend to use it as - background music, low or high volume etc? Do you have a space constraint issue? do you want to wall hang them, have them on the floor or on a bookshelf?
If you have no constraints, I'd go for the older of the S45's over CX50's. Whichever you choose, you'll probably have to work on them - refoam them at least. Can you try both speakers in your location before you make a choice?
Dave.
Thanks for advice, it is appreciated, and confirms my thoughts on the matter. Other advice also leans the same way.
Regards Kevin O'Connor👍
No I cant try them I'm afraid, but advice gives me more confidence in the purchase, so thanks very much, and I'll let you know how they sound when set up, so fingers crossed.
Regards Kevin
