I would endorse fully the recommendation for S45.2s as excellent speakers, particularly if used with their pedestal stands. ( I love mine).
If you are in the UK, an alternative to consider, although slightly less easy to find, are the Beovox 3800. These were a UK only model designed to maximise the benefits of arcane tax regulations over bass driver size. They were often recommended by dealers to go with the BM 3000 and its Beocenter derivative, the 3500, and if you like pop and rock music may be more suitable, particulary if you are going to use them in a reasonable size room - say more 25 sq mtrs. The S45.2s are accurate but are seen by some as 'bass light'.
Cleve
