Hi, will RL65.2 speakers fit onto RL45 speaker stands? Looks to me like they have different part numbers in the service manual.
Anyone?
I presume you mean RL60. As far as I know, all that matters is the mounting plate on the stand. RL140/7000 use the bigger plate, all the rest of the RL series uses the smaller plate.
So they should attach as far as the mounting plate is concerned, but the end result may look odd. Also, the bigger speaker on the smaller stand might only fit horizontally.
In short, a definite "maybe"...
Thanks for the input. Yes, I meant RL60. I put my brain into gear and checked the sizes of the 2 types, and apart from depth, they have the same dimensions for height and width, so these stands are advertised as RL45 but should be suitable for the RL 60 type as well.
cheers
Nick
The stands for RL45 and RL60 are identical and the speakers will mount horizontal or vertical.
Stands for the RL140/RL7000 are bigger.
Many thanks.
Nick
