speaker setup
My Bv7 has a 15pin connector the same as you use for computer monitors, is that a serial connection?
I'll upload some pictures of my menu screens in a little while, if that helps
Pictures of my BV7, I am assuming that quader has the same, When I select Format 0 my screen also comes up "Wait" for a couple of seconds before the curtains close.
I think you are right, quader got a BV7-40 MK I/II without HDMI ins, one DVI in and a VGA output for projector. Max. resolution is 1366 x 768.
Stefan
Hi there
OP have you connected your Projector to the DVI or VGA
Try and connect it to the VGA as the DVI is an input on ealier models.
Thanks Craig for the pictures there are what I have on my BV7 -32 MK1
It appears my current set up is hdmi connected to a splitter then to Sky HD and PS3
Sky HD is connected to the DVI
if you connect it to VGA would you not lose the HD quality ?
This may be why FORMAT 0 is not working for me.
If I have to use VGA connection then I will have to get a long lead as my projector is on a ceiling mount.
Do you have IR connected to control the projector via BEO4
"It appears my current set up is hdmi connected to a splitter then to Sky HD and PS3
Sky HD is connected to the DVI"
I think, Sky HD and PS3 are connected to a HDMI switcher which is connected to DVI-I input....(?), so you can choose between Sky and PS3 on the DVI input, am I right? Because a splitter connected to an input doesn`t make sense.
"if you connect it to VGA would you not lose the HD quality ?"
No. You have to connect to the VGA out - it`s labeled "PROJECTOR" - because this output will be activated by pressing FORMAT - 0.
"If I have to use VGA connection then I will have to get a long lead as my projector is on a ceiling mount."
Yes. I had 10 metres and it worked fine.
"Do you have IR connected to control the projector via BEO4"
Yes. I`m using a Lintronic box for the projector, the screen, lights, blinds...
Stefan
When you press Format and then 0 I believe the picture output is then transfered to the VGA socket, I'm not sure if you would lose HD as a result, Hopefully someone on here will know. You will need to use the VGA connector for you projector though. Also if you do connect your projector with an IR lead you may not be able to control your specific projector with the a Beo4, only the 2 projectors that are in the projector list, you may need to get a software update on your BV7 to add your specific Projector to the list for the Beo4 to control it, I'm not 100% on this so again hopefully some one on here can clarify.
Just to help anyone that's not seen the connections on a MK1 BV7, heres a picture of the AV3, AV4, DVI and VGA Connections
that is correct when you free format 0 the tv changes from its internal display to its external display VGA on this model.
VGA should give you a very good image anyway i dont think VGA carries HD to be honest but you will get an output.
As said before:
You can get HD resolution via VGA, not Full HD, because BV7-32 max. resolution is 1366 x 768. Same as BV7-40 MKI/II.
And pressing FORMAT 0 will activate the PROJECTOR out (VGA).
Stefan
yes you are right about the DVI connection,
Is there a name for this cable for the VGA connection,how much is the Lintronic box
Am I right in that when FORMAT 0 is applied i will be able to control which and how speakers are used.
