Speaker leads.
Hello again, another " newbie " question I'm afraid.
But first, just to say, I'm finding my way around this forum with regard to responding to answers. I THINK I've thanked everybody who has helped so far, I have tried, but in case I haven't managed it, my apologies.
Ok. I have a Beocentre 9500 with Beolab 6000 speakers. Would somebody advise which leads I need for those speakers and a 9500 phono please?
Thank you.
Hi Jonfey,
You need a pair of 8-pin DIN Powerlink Mk2 or Mk3 cables between the BeoCenter 9500 and the BeoLab 6000s.
If by “9500 phono” you mean a Beogram 9500 record player, then it should have its own 7-pin DIN captive cable that plugs into the Phono socket on the BeoCenter 9500.
Lawrence
In addition - if I may - please be aware, that Powerlink cables carry both left and right channel.
Means: you will have to set the switch on the BL6000’s to L or R according to their positioning im room.
Thank you for that Millemissen. I'm grateful. 🙂
Thank you for that Lawrence, I'm grateful. 🙂
The go-to guy for B&O-related cables is Steve @ Sounds Heavenly, or just go to his website. He’s a sponsor of this site, btw.
Thank you Steve.
                              Events have overtaken us now in as much as I have some. I got them prior to your post I'm afraid. I'm certain i'll need some more though as I have other items I want to connect. Thank you for your reply.  🙂
Thank you for your interest and answer BeoFrederick. Another contact made which is always helpful. 🙂
