Hi All,
After lusting for B&O equipment for years, finally jumped in the deep end and from owning zero, recently got hold of a 7700 Beosystem, 8500 Beocenter and 8000 Beocord.
Specifically asking for some advice on the 8500..everything works, no scratches just a nick on the glass panel under the cd side which isn't really visible so all good. Came with P30 speakers so ok I guess but felt wanted to get a more serious sound. Aquired a couple of 3800 speakers which decided to have as an interesting background to their development. Blinded by this, missed noticing the impedence of 4ohms compared to amp which is listed as 8ohms and the P30s as 4-8ohms.
Apologies if any technical terms not quite right, am not very electrical or savvy with setting up music systems apart from the basics (relative! :/)..
So my question, before plugging all the wires in and punching the self destruct button is whether these speakers can work in combo as a 4 speaker set up on this unit.
If not recommended, then not a disaster as building up the 8000 system and can fit together with this which is rated at 4ohms.
Thanks for any suggestions and apologies for what may be for many a rather silly question..
Regards
Andrzej
