Connect the BeoLink Passive to the BeoSound 9000 via a MasterLink cable (your local B&O dealer should be able to help with that), making sure you also have an IR sensor on the Passive.
Then, take a B&O remote control (assuming you have one), and pointing stright into the BeoSound 9000 which should be in standby (with the BeoLink passive unplugged from the mains), press LIST and STANDBY on the remote control at the same time. Use the up and down arrows to cycle through until you get to OPTION?. Press GO and choose A.OPT, and then press go again. Then press 0. What this will do, is disable the IR receiver inside the BeoSound 9000, because you want to use the one which is connected to the BeoLink Passive.
Now, you need to do something similar to the BeoLink Passve. Disconnect the BeoSound 9000 from the wall, and making sure the IR sensor is properly connected to the BeoLink Passive box, press LIST and STANDBY on the B&O remote at the same time, choose OPTION? and then A.OPT. Press go, and push 6 on the remote control. This will tell the BeoLink Passive that it's a link product.
Reconnect the BeoSound 9000 to the mains, and when you push CD, the IR sensor connected to the BeoLink Passive will pick up the IR signals, and wake up the BeoSound 9000, which will then pass sound back down the MasterLink cable into the BeoLink Passive.
Tell us if it works! You might even get a degree of hands on control, being able to push the buttons on the side of the BeoSound 9000 to choose CDs (although this won't wake the system up if it's all asleep).
