The lenght will not matter!
Each PL output on the Eclipe carries two signals - normally used as L/R.
This means that your Eclipse easily can send sound to a 6.2 setup of external speakers - if you count the speakers on the tv in and this is setup as the center channel, you can have a 7.1 with the Eclipse.
Note!
You can go even further, if you also use the WiSA connections there to compatible speakers.
Please have a look
link
and
here , if you want a deeper explanation behind the technology behind the way B&O televisions handles speaker connection/setup.
By the way….you will probably not benefit much from adding a BL2 to these two powerfull sets of speakers - both have even more ‘bass capacity’ than a single BL2.
But you can do it, if you please.
