Sourround sound options on the beo4 and connecting a Squeezebox to a bv8
Hi guys
I have a pair of bl4000 and bl6000 connected to my bv8-40, it sounds great, but I would like to use only the tvs speakers for normal television. I can read from the manual that the beo4 has a option called Sound under List. However, my beo4 is old and it does not have the Sound option, but i also have a beo5. How can I find the Sound option?
My second question is easy, I have squeezebox duet connected to Spdif 1, I choose AV2 and selected Spdif 1, but I dont get any sound :S Any ideas?
you have to use the SPEAKER option on Beo4. Press LIST until SPEAKER appears in the display and then 1 for only the internal speaker of your BV 8-40 (or p.e. 5 for all speakers).
/Räuber
I know about the list, but my beo4 does not have the speaker option, this is the problem
You need to add "SPEAKER" as a virtual button of your "LIST" (as described in the Beo4 manual).
- Press "STANDBY" (red dot button) and "LIST" simultaneously.
  (Beo4 display should display "ADD?" - if not - repeatedly press "LIST" till display is showing "ADD?")
- Press "GO"
- Press "LIST" until "SPEAKER" is displayed.
- Press "GO" - the Beo 4 should display "ADDED"
To select a function/source of your "LIST"
- repeatedly press "LIST" until the desired function/source is displayed
- press "GO" to send the command.
(Found in this forum)
Best regards
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thank you! worked perfectly!
How about my other question? does the bv8 support digital input?
Yes, the BV 8 support digital input.
I don´t have a sqeezebox, but it should work. May be you have to change the sound format of digital output of the sqeezebox. Try PCM or dolby digital.
/Räuber
well there are really no settings, it is a squeezebox duet do it is pretty simple :(
