Soundproof's Guide for using iPhone or iPod Touch as a remote!
Hi Soundproof
Great set of emails detailing how we can use an iphone & touch with our b&o gear - it must have taken you ages to write! I have a bit of a problem that you might be able to help with - please? - The A.Aux socket on the back of my 2300 is already in use - it goes to a beolink converter to patch it into the masterlink - is there a splitter available do you know - can I cut into the cable as you can masterlink? I have a bv3 CRT but that doesn't have any connections that I believe are appropriate? I would like to eventually get both audio from itunes and video from my mac onto the screen. I did think that audio would be relatively plain sailing but now because of the above I'm not so sure! I'm also not having much luck finding a DVI to Scart converter if there is such a thing that'll work as it should - I have found the Gefen one but there seems to be a lack of info on it...? Given the fact my TV and 2300 are in two different locations it will be problematic to run cables to each - can i use a spare audio coax on the TV to get the sound from the mac and still use it in the same way? - otherwise I may have to settle for just audio until I upgrade the TV, but I can't see that happening anytime soon!
Any help gratefully received. Thanks
JB
JB,
you can connect your mac to an AV-socket using a SCART-adapter. You will need a DVI - video-adapter for the mac. See apple store or Gefen.com. If the BV3 has a stb controler with apple codes you can control the mac with Beo 4, also from linkrooms.
Stefan
After reading this article, I rushed to the shop and bought me an itouch (no need for phone as I am in love with my blackberry).
What a great piece of electronics! I have connected mine through apple's Remote software and it works flawless. Within 15 minutes (first updateing the software) I had it all working.
I'm a very big B&O fan and would not doubt to buy anything else than B&O for audio/video in my house, but this ipod touch with remote is a masterpiece. Finally I can choose what cd to listen to from one of the link rooms (through beoport) without trying to find one with the up-down and colour arrows.
This keeps just one question remaining: why has B&O not been able to give the beolink 5 these (simple) capabilities? Although I'm one of their biggest fans, I have to admit that this is just a lost chance for B&O.
Looking forward to the BS5!
Hi Stefan
Thanks for your reply. I've looked at the apple store and have seen the adapter taking the DVI to composite, which I suppose I can plug into a scart plug with appropriate plugs. I'm not sure if this will allow both music & video to be distributed but I'll take the plunge and see!
Cheers
JB
There is no audio on the DVI out.
You can use the headphone/line out of the mac. Connect it via a 3,5 mm plug - rca (red and white) cable. You will find 2 rca inputs on the SCART adapter.
Stefan
Ah - good point. I had read all about the DVI interface last week but had conveniently forgotten about it!! Thanks for pointing that out. I now remember earlier in the thread about using the headphone plug on the mac with a simple lead or to take it further/better with using another piece of kit in the line - I'll try the headphone first...
Thanks again
 JB
Meanwhile I am waiting for my iPhone 3G I bought a iPod Touch 8GB for using as remotecontrol
I have Beomedia 1 and can now pilot my music with iPod, same as you who have Beoport
I just installed iTunes in "Service Menu" and add all my musicfiles.
So now I have just to press A-PC to open "soundport" on my BV9, or in any Linkroom 🤩
Congratulations! Why don't you write up the details of how you did it - it might be useful both for members and dealers who wish to prepare something similar both for existing BeoPort/BeoMedia and for the "who knows when it arrives" BeoSound 5? I'd imagine you can control playback in the same manner, using a Touch or iPhone?
exc guide , soundproof , well done
then again you ARE a mac guru
so nuff said :)
