Hi Soundproof
Great set of emails detailing how we can use an iphone & touch with our b&o gear - it must have taken you ages to write! I have a bit of a problem that you might be able to help with - please? - The A.Aux socket on the back of my 2300 is already in use - it goes to a beolink converter to patch it into the masterlink - is there a splitter available do you know - can I cut into the cable as you can masterlink? I have a bv3 CRT but that doesn't have any connections that I believe are appropriate? I would like to eventually get both audio from itunes and video from my mac onto the screen. I did think that audio would be relatively plain sailing but now because of the above I'm not so sure! I'm also not having much luck finding a DVI to Scart converter if there is such a thing that'll work as it should - I have found the Gefen one but there seems to be a lack of info on it...? Given the fact my TV and 2300 are in two different locations it will be problematic to run cables to each - can i use a spare audio coax on the TV to get the sound from the mac and still use it in the same way? - otherwise I may have to settle for just audio until I upgrade the TV, but I can't see that happening anytime soon!
Any help gratefully received. Thanks
JB
