Hi all,
I own a couple of beolab 8000 speakers combined with a beocenter 2300.
This combination sounds excellent with a CD input.
I have connected my Panasonic Plasma TV and mediabox from the RCA to the aux in of the beocenter, which allows me to use the beolabs to view movies or to listen to music from the mediabox.
When i use the TV as a source the soundquality is much better than using the mediabox as a source.
Question1: I was wondering if I could improve the soundquality from these inputs by using an external receiver (like the yamaha RX-V667) as a pre-pro attached to the aux of the beocenter 2300?
I'm also planning to attach a couple of beolab penta's to create a home theater setting. I can use the yamaha RX-V667 as a pre-pro, but I have to attach the beolabs directly to the pre outs of the receiver. This will definitely improve the soundquality of movies, because of the decoding of DTS-HD,etc. , and having a surround setup.
Otherwise this will imply that I have to attach the beocenter 2300 to the RCA in of the receiver to play CD's.
Question 2: What will a Pre-pro do with this sound and is it possible that the sound quality of CD's will decrease using this setup?
Question 3: Are there any positive or negative experiences with attaching external receivers (e.g. Yamaha RX-667) to Beolab speakers?
Many thanks for your replies.
