Sound quality of beovox 4500 on a beocenter 9300
Francois1er wrote:
but I want to make sure that the sound meet the appearance, or at least remains at a respectable level.
In fairness, the BV3000 are not *truly* "directly" connected to the BC9300 right now as I had stated... my mistake.
They are connected to a BL Passive amp connected to a BS1/BV4 as L/R channels. The BC9300 is ML'd to the BS1 and the BV3000 will play as stereo when using the audio source. The amp in the BC9300 and the amp in the BL Passive are similar enough, so... same difference!
After an exhausting day in the BW forum trenches... I need a drinky-poo, so I will be happy to fire up some '80's and report back later!
P.S. All of these Mondrian style speakers are notorious for blemishes especially in the metal. Look at them the wrong way, and SCRATCH! My advice would be to buy the BEST cosmetic ones you can find. The rest can be sorted!
The amplifier in the BC9300 does not go below 70 Hz (!) so that's a major shortcoming. (BC9500 starts at 20 hz)
I *believe* they are rated identically, no?
20-20,000Hz
70 seems rather high... for anything???
Frankly, I did not notice
I have had them both, the 9500 and 9300, with beovoxes the 9500 sound much better, with beolab I don't know if there is a difference because then the apm isn't used. Besides I read on this site that the used components in a 9300 are of a lesser quality than in the 9500. The makeover was clearly intended as a cost-saving operation.
Francois1er wrote:
The difficulty, maybe the silliness, of my question is that it is difficult to have an absolute  answer to a question which remains very subjective. Did anybody have the chance of hearing them and the beolab 2500? How did they compare?
I have both BL 4500 and BL5000 and I once had a pair of 2500's. I was a bit disappointed with the sound of the 2500's.
The 4500's sound much better. But either it's -Vox or -Lab I will recommend a subwoofer because of the lack of deeper bass.
The BL/vox 5000 has a better sound (more bass) because of the larger volume (approx. 2x size). The bass level of the 5000 can never be reached by the 4500's. If you turn up the bass on the Beocenter too much it will sound unnatural.
I use my 5000's without subwoofer -while I use a subwoofer with the 4500's. The overall sound from those speakers is really good -they are very open and detailed. And as said before -they are probably some of the most beautiful speakers ever 😐
Hello Steffen,
is it complicated to add a subwoofer?
A casual inspection of my 9300 connection did not reveal any middle or sub woofer output.
Be seing you,
François
It is not complicated. There is several ways to connect subwoofers to B&O. You can use the Powerlink connections.
There is a lot of different adaptors on the market -and you can find threads about it here on Beoworld. Here is one:
/forum/imported-unmapped/beocenter-subwoofer-enquiry#post-2249996
Good luck
Steffen
Hello everybody,
many thanks for your valuable advice. Meanwhile, I know I can only have 3000 or 4500 (veto from Ms. regarding the size of the 5000, which I preffered. And who said that size would not matter for women...) In blue.
It seems that beolab could be better, due to the shortcomings -alleged, as they say in the news -- of the BC9300 in terms of amplifier.
3000 and 4500 are basically the same, Thus, I can say:
"beolab or not beolab, that is the question" as they say in some Danish play 😁
Be seing you, François
