'Sound mode' on Eclipse
Hello everyone and happy new year,
on Beovision Eclipse v2 can you see in which sound mode you are playing while watching tv?
On beoremote one or sound center is possible only to set it
On the B&O app It does not appear.
Do you have any suggestions?
If you look in the User Guide, page 7, you can see how to see the current sound mode:
https://support.bang-olufsen.com/hc/en-us/articles/360052257492-Beovision-Eclipse-2nd-Gen
PS: It also works on my 1st gen. Eclipse ๐Ÿ™‚
Best regards
Dyssegaard
Thanks for your reply !
User Guide on page 7 is the list of 'sound modes' on BRT1 and of course you can choose ones, but it does not tell you which 'sound mode' you are currently using.
Youโ€™re welcome ๐Ÿ™‚.
I have right now tested it again on my 1st gen. Eclipse, and here are the changes I do on the Beoremote reflected on the Sound Info page. Also when I switch between inputs with different sound modes, the Sound Info page is updated with the actual sound mode.
However, this could be one of the differences between 1st and 2nd gen of the Eclipse.
Best regards
Dyssegaard
If you install the B&O app on a phone or tablet, you can see the current sound mode by selecting your Eclipse, then going to Product Information then Settings or Parameters (I am translating from French menus) and there will be a sound information tab. The current active audio mode will be shown there.
Regards,
Jean
Unfortunately in the V2 there is no 'Sound mode' in the Sound info of the B&O app.๐Ÿ™
This is the snapshot:
Yes, this is the right screen.
Is the TV on and connected to a source? If yes, then it's a bug and that must be reported to B&O.
I have a first generation Eclipse and the audio settings are displayed when the TV is on.
Jean
thanks,
i opened a ticket to b&o support.
Hello all,
This is the reply from B&O support
โ€˜This case has been forwarded to our headquarters for further review and you will be notified as soon as there is feedback or a possible solution is provided.
In the meantime, please do not hesitate to contact us again for further inquiries or assistance.
Kind regards,
Elliot | Bang & Olufsen Support
โ€”โ€”โ€”โ€”
I also have a couple of questions for you
1. How can I wirelessly connect my H7 headset to the Eclipse?
2. From Eclipse spec it says it doesnโ€™t support Spotify connect. But I use it quietly in streaming via iPhone/iPad to the sound center of Eclipse . How is it possible?
Many thanks for your suggestions
Massimo
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
