Sound delay
Millemissen wrote:
Don't forget - you will have to configure 'Audio-default' as speaker 4 (or even 5), unless you want to chooe it manually eery time.
Hi :-)
Could you please explain how you go about configuring 'audio-default' as speaker 4 please?
i have a similar set up to you guys in this thread (BV5 /penta labs/8000's & BS9000). All 4 speakers are connected to BV5 and BV5 connected to 9000 via masterlink cable. But when I switch on any source, audio or DTV, only the fronts (Penta's) active, and the BL8000's remain in stand by. I'm having to manually turn them on via List-speaker-4.
Can i configure so all 4 speakers always come on? If so, could you explain how to do that please?
Thanks very much & regards,
I'm not sure the software on the BV5 supports that option... ( I could be wrong though - I'm not in front of a BV5)
I know that the later software on the BV7/BV9 gives you the option to select default speaker options for Audio and Video (for example "Speaker 4 for Audio / Speaker 5 for Video) - but I don't recall the BV5 SD supporting this...
Lee
Ahh cheers for that Lee, I guess its not too much trouble to press List/speaker/4 anyhow
Thanks anyway :-)
I suppose 9 LEE is right - sorry.
