Sound along with dvi on beosystem 1 + bv4?
I have connected a computer to the dvi socket directly on the beovision-4 plasma, but how do I get analog sound along with the picture? Right now I have the picture (dvi-cable) assigned to dvd/dvi-d on the av socket in the connections menu.
If I use a rca-to-scart-cable and plug it into one of the sockets to get audio that way, wont the dvi picture be lost then and the system switches over to scart only?
Figured it out, I connected it to the camera input. The menu was a bit tricky since you have to press menu when the connections option is highlighted
Thanks for your feedback on solving this issue. Will help others in the future.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
