Sorry to be a pain...
Hi
Sorry to be a pain if this has been asked before, but is the new telewest/virgin media V+ box compatable for operation through the Beo4 handset. I'm asking this cos if it is then this is a good excuse to persuade my other half to buy several Beo5s.
Thanks.
Brian
The Beo4 does not control any non-Beo products.
Your TV might control non-Beo product with a PUC or a STB-C.
The list of devices is available in the menus.
The Beo5 will control non-Beo products, but it seems more targetted to non-AV products, like curtains, etc...
The official solution for controlling non Beo AV products is the PUC or STB-C in your TV.
When people have received their Beo5 we may know more. I wouldn't order one before being sure it can do what you want.
 p.
Thanks for your help, yes I already have stb-c and my beo4 does control the old cable box in main room and around the house, I just wondered if the new V+ box could be similarly controlled.
Brian
Take the current remote control that came with the set top box, go to a shop and try it on the new V+ box, if it works, then the Beo4 will be able to control it with the same settings, though the STB-C
Yes it is possible.
Having said that I have as yet to work out how to exit the V+ menu system back to the TV screen.
Hval
