Some Eclipse 65 MK1 Questions
Hello Beofans.
I have some Eclipse MK1 65 questions if anyone knows any answers
  1. LG say the disney+ App is compatible with WEBOS3.5 but it does not appear in the store in the UK, has anyone found a solution to this? Disney also show it on the compatibility list for this panel
  2. If using Apple TV with PUC when the apple TV is connected to the sound centre you have to use IR for the PUC control right? If you connect the Apple TV 4K to the Screen HDMI do you still get Dolby and control the Apple TV without a PUC IR Blaster.
Happy Sunday.
Seanie_230 wrote:
Hello Beofans.
On September 9th 2021 I received the following feedback from B&O support (translated from danish):
We have now received a response from our head office in connection with your case. They are aware that Disney + is currently not available on the first generation Beovision Eclipse and are in dialogue with LG about it, however, there is nothing new in the matter, which has unfortunately dragged out.
A temporary solution to the problem would be to acquire an AppleTV, or another set-top box, as this will allow you to access Disney +. It is just a suggestion and I understand well that it is not an optimal solution.
As of today - still no joy 😕
Best regards
Dyssegaard
Thanks for the reply
Another question
I plugged my laptop into the TV hdmi 1
Options are only stereo rather than 5.1 is that normal?
