software updates
my b&o techno delivered the new fret for my beo10, and updated the software on my beo5 and beovision 10, unfortunately i was out at the time and my wife forgot to ask him.
beo5 software 145b
beovision10  software build 166
anyone know what they correct
malcolm
As discussed in this thread:
/forum/general-discussion-and-questions/audio-issues-with-beovision-10-46-bass-adjustment#post-1942997
Build 210 is the latest software build for Beovision 10-46.
Mine is being updated tomorrow morning due to sound issues with build 165 / 166 that I currently have (cannot remember now which one).
I don't know if the software build differs between MK I and MK II Beovision 10 models, though... I have a MK I.
my tv is beovision10 -40
anyone know what these updates correct
166 for bv 10
145b for beo5
malcolm
The newest software for all BV10 and BV8-40 is B224.
Don't know about the Beo5
Hi Malcolm,
My BeoVision 10 was updated on Saturday, and I asked my dealer about the software versions.
The latest software for BeoVision 10 is build 224, so it appears that you still have the old (166) software, same as I did before the update. You should ask your dealer about this -- it seems your television's software has not been updated.
After the update to 224, the TV seems speedier (menus) and the sound is better, at least to my ears. I could swear there's a slight improvement in picture quality as well, but that may be a pseudo-effect, as I'm trying to spot improvements after the update. Some new items have also appeared to the Customer Service Menu.
Perhaps someone at BeoWorld has the full list of improvements with build 224?
As for Beo5, I think Keith Saunders, the Beo5 expert, has the best answer:
http://forum.beoworld.org/members/Keith_5F00_Saunders/default.aspx
You could also check the Beo5 forum at http://forum.beoworld.org/forums/48.aspx and do a search on the 1.45.
many thanks for info have e mailed my dealer to update tv next week i suspect carvival time here so closed most of the week
malcolm
Can Any one tell me what the improvements are?
