Software BV Avant NG Mk II (75)
Following up on this thread.
A few restarts and an overnight rest seemed to have cleared everything up. Not sure what the issue was, but everything is back working fine. Hopefully, just a random glitch in the matrix 🙂
Would be nice, though, to get more functionality from the operating system, but my hopes are just that. Great TV otherwise.
Most of these annoyances can be taken care of by clearing the cache in the Android side of the TV. Clear that and response should return.
Thanks for all your ideas!
I managed to improve the satellite signal and I think this also helped; a bad signal - could it be a reason?
but: my bad dish signal was caused by a splitter which is needed to feed the twin receiver; now I lost the ability to record....do you know any high quality splitter for a unicable installation? Any idea?
