So I went ahead and bought my first Beocenter 1
Okay, I know it's dated but I have to say I'm pleased and it's so beautiful. I'm not much into Bluray, and ultra and all that, as it seems a pain to keep replacing your tv and radio with DAB+ and all that.
This is my first B&O product. A 32" Beocenter 1, with built-in DVD. Love it!
Now I'm looking into Beosound 3000. Though not sure about the 3200 and what to go for.
Congratulation for your first B&O acquisition!
It is really very nice B&O TV with superb picture. If you does not matter the size, you could be very happy with it.
If you want to integrate the next acquisition (Beosound 3000 or 3200) with the TV, check first if you have the Masterlink module built-in in yout BC1. I think it was build-in or not when it left the fabric and it was not possible to add this module afterwards. There are not many of them with this module I've seen.
Regards,
Theomaster
The 3200's "advantage" is the recording-function. The recordings are made in low-resolution. I would recommend the cheaper 3000 instead.
Leos:
Thanks for advice about the 3200. The good thing is that the Beosound 3000 is pretty darn cheap to get. I'm looking for the one with the grey CD stand.
The O Master
Thanks, I'm not sure what Masterlink is, but will google it - is it some sort of a connection?
