Smart TV
Please accept my apologises if this topic has already been covered but I do not recall if it has. My BV7-40 Mk 6 with blu-ray (see Flash your B&O page 7) needs to be converted to a "Smart" tv.  Apparently it requires an Apple TV which can be attached to the back of the BV7, but it seems that there are more that one type of Apple TV.  For example, when checking on Amazon (UK), one model is suitable for the USA which another is ok in Hong Kong.  As I am in the UK these particular models do not seem the right ones. Furthermore, there could even be be a newer model due to be released later this year.
Can anyone please shed some light on the best way forward, e.g. which is the appropriate Apple TV, what cables are required, can one use the BEO 4 remote etc.? I am definitely not technically minded (very strong confirmatory statement from SWIMBO) but my computer has quite a good Fritz Box router, if this information is of any use.
Many thanks in advance
Villarsch
EDIT : Delete !
Hi Villarsch,
please don't forget that, if you want to control it with the Beo4, you will need the right PUC-code. With the BV7 you will need a B&O technician for updating the list of PUC's in the tv.
You connect the ATV simply with an HDMI cable to the BV7 - for the controlling vith the Beo4 you will need a (PUC) cable from the tv to the AppleTV box as well.
In most cases the Apple-box can connect to your network via WLAN, but - if possible - it is best to use a normal network-cable from the router to the box.
Many thanks for all your useful advice.  I shall be contacting my local B&O dealer (always very helpful) and hope to have a "Smart" TV very soon.
Thanks again,
Villarsch
