SLG error 30 and 32 on BS9000 MKII
i got the errror when run test 27 i got SLG error 30 and 32 and now 33 and 41.
Right now the cd tray is stopped at cd 4 and will no pickup any other cd or play the cd. its restart automatic.
How can i fix this problem?
I would start by cleaning the sensor beneath the sledge. There are 2 white surfaces which aren't  white anymore. Detection fails.
And when you're cleaning, I also would clean the mechanism by removing old hardened grease as far as you can reach.
Hi.
the white sensor , where are they? under the cd laser? i have take the clamper arm off and cleaned the clamper arm and the laser, but no white surfaces. Can you give me a hint?
I have clean all i can see and now its works agian :) .. I only got one error SLG33 when i run from cd6 to cd 1.. but the bs9000 now plays.
Take the bottom plate off. Then the white surfaces are visible under a small circuit board.
