SkyQ update now limited control with Beo4
Sky updated the SkyQ silver and the Sky Minis overnight. The Beo4 has been controlling the boxes very well since the PUCs were installed on two BV-10 but now only has limited abilities. No fast forward or rewind and two presses for almost every other operation in the Sky EPG. The Sky remote operates normally so I have no idea why the Beo4 no longer works. Anyone else having the same problems ?
I have had the upgrade to SkyQ with my Beovision 7 40 and a Beo4 without the navi button and everything works like it used to. Though I have never been able to fast forward but only to jump forwards, and not sure if there are other functionality I can't use but all the menu functions work.
Thanks patcherly. It’s controlling the mini boxes that’s most changed. The main SkyQ silver box is with a beo1 remote via the BV-14 PUC and that is still fine like your BV-7.
beoair, I have my Beovision 6-26 working the same as the Beovision 7 40 but with a MiniQ and a Beo4.
