Sky record button combo from a Beo4?
Ok, since buying my BV10-46, it appears to have a new Sky remote PUC which is different from the one I've been used for for the last 5 years!
For example, using my BV7 and Beo4, to record a Sky programme, you simply pressed GO + red button. Now, that sets the timer. So, how on earth do you record a Sky programme using your Beo4?
Go and 8?
If you press menu, does it not overlay all the available options down the left o the screen? if you are ona link room, press menu in front of the main tv to see which option you should be using
rednik wrote:
Go and 8?
Thanks, that's the one! Should have looked it up, but thought it was quicker to ask the question.
Go red also
And if you press menu once you will get the conversion on the side menu that appears
Seanie_230 wrote:
Go red also
As I said, it doesn't work.
Kind advice anyway Seanie.  Moxxey that sounded dam rude!
Not rude Tod, I was (and am) annoyingly quite ill, so only managed a few words. Wasn't supposed to be rude. But forums do that. People interpret written words very differently than body action.
Anyway, thanks for the help guys!
Hello
Dont worry I did nt read it in a rude way.
Get well soon...
Seanie_230 wrote:
Hello
Get well soon...
Thanks Seanie. Lot better tonight - I think it was just one of those end-of-week run down things you can get after a hard week!
