Hi all,
I am having sky+ fitted today! I have had the stb chip upgraded last year has anyone got a map of which button will do what on the beo4? Cheers Nick
Hi all,
The card I have is rubbish! Your dealer should be able to give you a bigger one but essentially GO and whatever you want will do most things. Go + Red records and GO + << or >> fast forwards and reverses. Sky + integrates with my Avant brilliantly and also works in the link rooms fantastically. I am sure you will find it a very good addition.
Thank you for the response, if its not too much hassle would you be able to list the commands for me? Many thanks Nick
hi
In search on this web page type in sky commands for beo4
in there pdf file with picture of all commands which you can print off
malcolm welborn
Thank you I did do a search but to no avail, now trying what you had put and all sorted! Thanks Nick
All working! I must say that sky is far superior to virgin media! Finished tidying the cables and fixing the box to the avant.
yeah good idea, that would make it neat and tidy!
Never realised that that space was empty - is it ok then for the Sky+ to go there - not too much heat or anything? it would clear up so much space and less cables!
